dumb question
Old Aug 6, 2009 | 09:19 PM
dirt neon's Avatar
dirt neon
Question dumb question
will neons run without o2 sensors? im told that the o2 sensor in mine could be bad so i was wondering if i just took it out would it run right? see i said it was a dumb question
Old Aug 7, 2009 | 02:41 PM
Altima_wb's Avatar
Altima_wb
it may run but it won't run right.... deff need to replace the sensor with a new one probably will help both performance and milage
Old Aug 7, 2009 | 09:49 PM
dirt neon's Avatar
dirt neon
ok thanks.
Old Aug 11, 2009 | 09:29 AM
spudsterier's Avatar
spudsterier
the car will run fine without a downstream 02 sensor, but you do need an upstream
Old Aug 11, 2009 | 12:44 PM
ottoretto's Avatar
ottoretto
well my car do not have the o2 sensor! do not have the downstream and upstream!, and runs pretty good!!
Old Aug 11, 2009 | 01:23 PM
whtdoesitmatter's Avatar
whtdoesitmatter
or so u think. have u checked for ghost codes? have an a/f gauge or some other type of monitoring system?
Old Aug 12, 2009 | 02:59 PM
Altima_wb's Avatar
Altima_wb
yeah the downstream isn't needed its just there to check the function of the cat...
Old Aug 13, 2009 | 01:10 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Why not just replace the sensors? What is wrong with that?
