Bigger Chrysler Injectors??
Old Aug 8, 2009 | 03:20 PM
ldiablo233's Avatar
ldiablo233
Default Bigger Chrysler Injectors??
The 95 neon I pulled a Cam from today at the JY had these same injectors in them:
http://images.google.com/imgres?imgu...a%3DN%26um%3D1
Mine are like this:
http://www.injectorz.com/images/mp-54329.jpg
Same pin style and it has a Chrysler symbol on them.
Probably a no, but any advantage using these on a stock-ish engine?
Old Aug 15, 2009 | 05:04 PM
bad venge's Avatar
bad venge
Section Moderator
You'll need to do research and find out HOW MUCH these will flow versus the stockers you currently have
Old Aug 16, 2009 | 03:13 AM
ldiablo233's Avatar
ldiablo233
Well it kind of ran weird ,seem like low RPM full throttle was better but it kinda felt weird. Hard to tell with my oil problem but I just went back to stockers. Wouldn't they create the same pressure thats in the fuel rail? Also, is this the purpose of a fpr, to control the pressure on the injectors?
