1st gen gauge cluster repair
Old Mar 22, 2007 | 06:49 PM
BadBrads97Neon's Avatar
BadBrads97Neon
Default RE: 1st gen gauge cluster repair
ORIGINAL: das2123
Not all 95's are equipped with the tach wire, but some are. Plug it in and see what happens. Don't forget to swap your odometer into the new cluster to keep your milage correct.
yeah I just learned how to do that thanks das
Old Mar 22, 2007 | 07:03 PM
lydo's Avatar
lydo
What symptoms does this fix? Them not working at all or something else? Right now my gages sometimes go nuts. The needle in the gauges move up and down like an equilizer. Could this fix the problem?
Old Mar 22, 2007 | 07:39 PM
das2123's Avatar
das2123
ORIGINAL: lydo
Yes it could.
Old Apr 14, 2007 | 01:23 AM
boxerjl2's Avatar
boxerjl2
wait wait how do you change out the odometer ill have to go check this Out!!!!
Old Apr 14, 2007 | 01:57 AM
das2123's Avatar
das2123
ORIGINAL: boxerjl2
Just take all the screws out and pull it out and swap odometers. You will need a T9 torx bit to the the final 2 screws that secure the ododmeter.
Old Apr 14, 2007 | 02:25 AM
boxerjl2's Avatar
boxerjl2
yeah i did that it was super easy cannot believe i never thought of it do you have to torx it ???
Old Apr 14, 2007 | 02:29 AM
das2123's Avatar
das2123
Not torque, but a Torx bit.
Old Apr 14, 2007 | 02:33 AM
boxerjl2's Avatar
boxerjl2
lol.. yeah i got it thanks lol wow i feel retarted
yeah it should work out pretty good i just got the new cluster today and still no speedometer so im going to need some help that the 4th cluster ive put in my car everyone says its the cluster ITS NOT THE CLUSTER
Were Is The Speed Sensor On A 98 Dodge Neon Unforntnantly An Sohc
but i might upgrade as soon as i get a better job
haha my heater core went out yeah!!!!
so i just unpluged the hoses going into the heater and hooked them together for the time being . so i dont have a heater
SPEED SENSOR CABLE LOCATION PLEASE!!!
not yelling just very enthusiastic
thank you
josh
Old Apr 14, 2007 | 01:40 PM
das2123's Avatar
das2123
Your VSS is on top of the thanny held in by (1) 10mm bolt.
Old Apr 14, 2007 | 03:25 PM
boxerjl2's Avatar
boxerjl2
hmm ill go look i thought it would be a plug
