What is this?
Old Sep 20, 2009 | 10:21 PM
kj4cwa's Avatar
kj4cwa
Default What is this?
What wire/wires is this circled in green? Where do I get a new one? Thanks.
Old Sep 20, 2009 | 10:27 PM
kj4cwa's Avatar
kj4cwa
I guess it helps if I post the pic right?
Old Sep 21, 2009 | 12:16 AM
neisg1's Avatar
neisg1
Default Main Starter Power Wire
The red wire goes to the starter (Main battery power) you can see the red connector on the starter in your photo just below the intake manifold. The only place you will find a cable with the proper starter end connector is from the dealer of a wrecker.
Old Sep 21, 2009 | 12:47 AM
kj4cwa's Avatar
kj4cwa
What does the black wire do? Is there only 2 wires in that wrapping?
Old Sep 21, 2009 | 12:55 AM
master tech's Avatar
master tech
Site Moderator & Tech
Thats your ground.
Old Sep 21, 2009 | 01:16 AM
kj4cwa's Avatar
kj4cwa
So when I remove the battery, I take off the black wire first right? (I am such a noob.)
Old Sep 21, 2009 | 02:28 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Believe it is red first.
Old Sep 21, 2009 | 02:35 AM
Altima_wb's Avatar
Altima_wb
yup red first....
Old Sep 21, 2009 | 12:06 PM
neisg1's Avatar
neisg1
While it makes no difference to the car. It is generally safer to disconnect the NEG first. If you remove the POS first and accidentally short the wrench to the car body it will short out. If you remove the NEG first this is not an issue as the body is already connected to NEG. The Haynes manual also recommends NEG.
BTW my 95 has two black wires in that location one it the main engine/starter ground and the other connects the body beside the radiator.
