'98 Neon Blinkers stopped working
Old Apr 4, 2005 | 01:40 PM
flashburn's Avatar
flashburn
Default '98 Neon Blinkers stopped working
Something weird happened this weekend. I am not sure if it is a coincidence or not, but I got my car detailed (in and out) this weekend, and now I noticed that the blinkers do not work. I also noticed before this, that my front right speaker stopped working, but this has happened 3 times before due to loose speaker connections.
The blinkers on both sides, front and back and the indicator lights are not functioning. I checked the fuses and they are fine. Any ideas before I take it to a shop to look at?
Old Apr 4, 2005 | 01:51 PM
techmanbd's Avatar
techmanbd
Default RE: '98 Neon Blinkers stopped working
try the flasher
Old Apr 4, 2005 | 02:20 PM
flashburn's Avatar
flashburn
They also do not work.
Old Apr 4, 2005 | 02:42 PM
LowSlowNeon's Avatar
LowSlowNeon
I am having the same issue. I'm probably going to take mine into the dealer and let them look at it.
Old Apr 4, 2005 | 03:51 PM
techmanbd's Avatar
techmanbd
ORIGINAL: flashburn
I meant check the flasher relay. Sounds like that is bad.
Old Apr 4, 2005 | 04:53 PM
flashburn's Avatar
flashburn
I was driving home, and while driving I kept trying the blinker, and all of a sudden, it started to work again. Damn Neon!
Old Apr 5, 2005 | 03:47 AM
casper's Avatar
casper
Sounds like the multifunction switch or the flasher relay. If that does not work replace your blinker fluid, it could be bad, lol
Old Apr 6, 2005 | 11:23 AM
chud298's Avatar
chud298
ORIGINAL: casper
Yeah and don't forget those exhaust bearings lol. Good one casper, some people were prob confused when they saw that lol.
Old Apr 8, 2005 | 05:14 AM
ewetho's Avatar
ewetho
Not as weird as it sounds. After using the 4 ways one day the turn signals would not work. Then on the way to the dealership after notifing them I was on the way and they had a bay open, t turns away the started working again. Moral well maybe during the detail process wiping the area of the 4-way the switch had excess plastic flas that got stuck in the swtch mechanisim. Worked it's way out and all is well. All I could figure. Smile until it is a problem again.
Old Apr 8, 2005 | 09:47 PM
casper's Avatar
casper
Great to hear you got it workin, just remember to keep the blinker fluid full and you won't have that problem again, lol
