Gauge Clusters
Old Oct 13, 2009 | 04:18 PM
Nuklhed074's Avatar
Nuklhed074
Default Gauge Clusters
soo.. i searched and didnt find anything so i have a 95 sohc with no tach what do i have to do to put one from my dohc 98 with a tach? please and thank you
Old Oct 13, 2009 | 07:29 PM
bg1995redneon's Avatar
bg1995redneon
Yo Knucklehead!
The thread below (and it is a current running one)
https://dodgeforum.com/forum/1st-gen...e-cluster.html
should help you out. According to the guys who helped me, it is plug and play. Most 95 models came pre-wired for a tach.
I found and bought a cluster from a 95 that had a tach, but the 98 cluster you have should also work in the 95. Just pop off the dashboard top and unscrew a couple of screws, pop out the non-tach cluster from the 95 model, disconnect the plug from the back of the circuit board and compare to the 98 connector. The wiring diagram for those years are the same, so you should be fine.
I checked my car out while waiting for my "new" part, and indeed it is pre-wired, so I am getting impatient waiting for it so I can hook it up and give it a go.....
Old Oct 13, 2009 | 09:56 PM
Nuklhed074's Avatar
Nuklhed074
thanks man i greatly appreciate it man saved me alot of time
