Neon Transmission Help
ok what will fit what? i need the complete chart lol
sohc auto
dohc auto
sohc manual
dohc maunal all 95-99 can they all be interchaged?? answers plese and thank you
sohc auto
dohc auto
sohc manual
95-99 auto neon trannys fit all other 95-99 auto neons
95-99 manual neon trannys fit all other 95-99 manuals neons
sohc and dohc dont make a difference with autos....manuals will all work, but there are 3 different gear ratios
ok so would that also mean the auto trannys and manual tranny are the same? like could i put an auto tranny on a manual and visa versa like are 95-99 trannys pretty much universal
*fixed*
The 2G 1996-1999 eclipse mtx has the hydraulic bell housing and clutch mechanism also used on 2G 2001 + 2005 mtx neons/pt cruiser. The gears, however, and the same used in the 1G 1995-1995 neon acr & r/t. The transmission cn be used in a neon, by swapping out the hydraulic bell housing and using a cable bell housing in its place.
