Larger cam/Injectors?
Old Nov 2, 2009 | 02:31 PM
95neoncoupe's Avatar
95neoncoupe
Default Larger cam/Injectors?
i own a 95 neon sohc, i have plans of putting a larger cam in the car..can someone tell me if i will need to put bigger injectors into the car so i can get the full potential out of the cam.
Thanks.
Old Nov 2, 2009 | 02:37 PM
Captansavaho's Avatar
Captansavaho
it depends on how big of a cam you go? do all you plan on doing is the cam? or are you going to raise compression and so on? but a basic cam no you will have have to change anything
Old Nov 2, 2009 | 02:46 PM
95neoncoupe
well i want it to be larger than stock....do u have any sugestions on which one i should choose.. And no i didnt have plans of rasing the compression ratio..
Old Nov 2, 2009 | 03:39 PM
Nuklhed074's Avatar
Nuklhed074
use an r/t cam out of an 01 if you want to go cheap and then switch to dohc piston boost your compression up to almost 10to1
Old Nov 6, 2009 | 12:34 PM
95neoncoupe
well, could i use a whole top end off of an R/T..I have read that this swap will work but their is something goofy with the starter, you have to use one off an 01 neon, due to the larger intake manifold..Is this correct?
Old Nov 7, 2009 | 12:49 PM
Ghost Neon 2's Avatar
Ghost Neon 2
The cam from the 2001 r/t has a more aggressive profile than other OEM cam shafts for the sohc. Nothing to do with the intake manifold.
Old Nov 10, 2009 | 12:09 PM
Altima_wb's Avatar
Altima_wb
the 01 r/t cam is a great cheap upgrade but i would say if the car is your daily driver then either the r/t cam or go with the crane #12 or something of the like... your deff going to want to consider upgrading to one of the available aftermarket pcms to raise the rev limit and make full use of the bigger cam shaft... although the pcm is probably not needed with r/t cam but should at least be considered if going with the #12... bigger injectors really not needed unless you do a complete engine build or go turbo...
Old Nov 13, 2009 | 03:02 AM
Nuklhed074's Avatar
Nuklhed074
yes like im going with the comp 400 in my sohc so ill proly need bigger injectors and a pcm to get full use
Old Nov 15, 2009 | 11:16 PM
95neoncoupe
will any stage 1 srt4 turbo parts fit on my 95 neon sohc. My friend has an srt4 and is willing to sell me the parts cheap.
Old Nov 16, 2009 | 01:19 AM
Captansavaho
you need to switch to DOHC for use of srt parts or get an adapter which are hard to come by unless u can make your own
