Looking for turbo parts.
Old Jan 4, 2010 | 07:57 PM
Nuklhed074's Avatar
Nuklhed074
Default Looking for turbo parts.
Got a 14g t3 turbo. check
Got a Rev Hard Intercooler. check
Got a decent bov. check
Got a Hahn turbo Manifold. check
need a dohc modded pcm for boost.
need a fuel pump modded or jus info.
need Intercooler Piping.
need a safc (super air fuel controller)
anything im missing please let me know. thanks for the help
Old Jan 8, 2010 | 03:42 AM
Nuklhed074's Avatar
Nuklhed074
bump please guys needin help on fuel and pcm
Old Jan 17, 2010 | 10:50 PM
1fast2liter's Avatar
1fast2liter
you do not use a safc as it does nothing but add fuel at wide open or ideling.... you need to use a rising rate fuel regulator... or rrfpr you can not modiffy the stock ecu(pcm as you call it) for boost. their are only 2 choices for after market ecu's and neaither one is a good choice for boost you eaither use a stock ecu or go with ms=mega squirt.... as far as inter cooler piping look on ebay i used a kit off of ebay got it for like 120 shipped came with every thing i needed.. you can also use exhaust tubing to... you will also need a boost gauge to wich i have one some were brand new also....
a must have for boost is a wide band o2 sensore and a gauge to read it....
Old Jan 18, 2010 | 06:13 PM
Nuklhed074's Avatar
Nuklhed074
yeah i know what all i need and i can use a safc cause ill also have a ffpr already been looking into an aem.
Old Jan 18, 2010 | 07:31 PM
1fast2liter
no the safc will do nothing for you but add fuel at idle or wideopen throttle... with a rrfpr you need to turn fuel pressure down to like 30 psi or so to idle a set of srt4 stage 1's and you need the rrfpr to add fuel under boost.. at cruise the ecu will use maps already in the ecu to control fuel you can not modify that signal.
Old Jan 19, 2010 | 05:25 AM
Nuklhed074's Avatar
Nuklhed074
this i know but i can use the safc to tune for idle and wot and ill have both so ill be alright
Old Jan 19, 2010 | 05:28 AM
Nuklhed074's Avatar
Nuklhed074
also yes you can use the head from the eclipse but your exhaust will be in fron and intake in the back. im using a neon head but eclipse manifolds and yes your right about dropping comp that what im doin sohc bottom end and dohc top end
Old Jan 19, 2010 | 05:08 PM
1fast2liter
right but your looking at a problem here the way the mani os on a eclipse and were the turbo is you will need to modify the head... are you using a head from a turbo eclipse?
Old Jan 19, 2010 | 05:19 PM
1fast2liter
ok and about the safc.. you tell me why you need it.. ill tell you why you dont.. running srt 4 injectors? the stock computer will control idle.. you set fuel pressure for it to idle right.. a safc and a neon at a stock fuel psi and srt4 injectors will still flood out and not idle right aven with fuel trim all the way down... already determined at cruise the safc is usless.. ok at wide open throttle what are you gonne use it for to add fuel? still usless as the safc will not reconize boost so for that split second you didnt tune it into cruise engine will run lean.. with running a rrfpr it is still usless.. your adding more fuel pressure wich is pushing a crp load more fuel thru the injectors do to increase in fuel pressure.. the safc will not be needed as every thing will be controled by the rrfpr. a safc really only works if your car has a maf sensor as say eclipse does.. or you are running some radical cams in your neon as a neon will run richer with radical cams at idle and go lean at wot.....i have ran all 3 setups in my neon.. i know how all three work and run...
Old Jan 19, 2010 | 08:26 PM
Nuklhed074's Avatar
Nuklhed074
so i shouldnt run a safc just a ffpr. alright could you give me a link to a good one to look into?
