ok i did key dance
Old Jan 15, 2010 | 03:06 PM
crazydesigns's Avatar
crazydesigns
Default ok i did key dance
ok today i did key dance on a 98 2.0 sohc could any one let me know what 12,42,44 are?
Old Jan 15, 2010 | 03:27 PM
Tizzy1's Avatar
Tizzy1
I don't find anything for 12. 44 is for the ambient/battery temp sensor and 42 is pretty broad, it is the ASD or Fuel pump relays.
Old Jan 15, 2010 | 03:35 PM
bg1995redneon's Avatar
bg1995redneon
12 battery has been disconnected within 50 key cycles. Ignore it.
42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
This is your problem area and you need to check out the items listed above. It is easy to check the fuel pump and ASD relays as you can use the Horn relay (same one) and use it in place of each one to see if it makes any difference. New relays are anywhere from 15 to 30 bucks. Rockauto.com and partsgeek.com seems to have the lowest price I've found for relays.
If it is the fuel pump and/or fuel level sending unit, that requires you to drop the gas level to as empty as possible, lower the gas tank, and take out the entire unit (it contains pump, filter, and fuel guage unit). Replace it with a new one and shop around because prices vary wildly.
44 Battery temp sensor volts out of range. This one is annoying, but not a cause for worry and can be fixed at some future time if you want to keep this error code from reoccurring.
Old Jan 15, 2010 | 04:13 PM
crazydesigns
12 i can ignore cause i had battery out while wiring in new fuse box and 42 more than likely a relay cause fuel pump and everything was working before and im not hearing pump come on so hopefully thats it cause it came on before and 44 i know why it was my dad broke the sensor pulling it out of battery tray thanks guys
Old Jan 15, 2010 | 04:27 PM
crazydesigns
so it start now everything works good now to do some double checking and get temp gun out and see if its getting hot again then on to pulling dash and getting it ready for paint
Old Jan 15, 2010 | 04:46 PM
bg1995redneon
Send me a private message with your name and mailing address and I'll send you a new battery temp sensor for nothing. I have an extra one and don't need it.
Glad you got it going.
Old Jan 15, 2010 | 05:08 PM
crazydesigns
sent and thanks me to.
Old Jan 15, 2010 | 06:45 PM
Altima_wb's Avatar
Altima_wb
hey to check the fuel pump relay or the asd relay... just swap them with the horn relay... they are all interchangeable... when i tested mine i just swaped them one by one into the horn spot and honked the horn... if the horn honks with each one in there then the relays are fine... then you will want to see if the pcm is kicking the relay on when you turn the key. Just have someone turn the key to the run position while you have your finger on the relay... if you feel a click then thats working right then your to your fuel pump... if for some reason you don't feel a click then you need to figure out why your pcm isn't kicking the relay on...
Old Jan 15, 2010 | 07:05 PM
2000dakota4x4's Avatar
2000dakota4x4
Is this trick true of most relays, and or cars? Great idea! Thanks.
Old Jan 16, 2010 | 02:38 AM
Altima_wb's Avatar
Altima_wb
as far as being interchangable like they are on the neon not always but a lot of times yes... and as far as the relay clicking yeah they all do... basically all a relay is, is a switch that is turned on/off by the flow of electricity.......
