2.0 DOHC 13g turbo project
Old Apr 26, 2005 | 01:25 AM
Sask 98 R/T Wanna_Be's Avatar
Default 2.0 DOHC 13g turbo project
[size=2]Hello,
Would anyone have any knowledge or advice about me putting a 13G turbo on my '98 Neon DOHC. I know it isn't the best turbo to use but I am on a budget and can only work with what I have. Thanks
[IMG]local://upfiles/15366/A641563E20344472B01BA0C1C7813E11.jpg[/IMG]
Old May 6, 2005 | 03:09 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: 2.0 DOHC 13g turbo project
Well 1st you need turbo downpipe, piping, lines, hoses, U also need a turbo header for quick bolting, An intercooler isnt a bad idea to have, you will need a compression ratio of 8:5 and upgraded internal for maximum performance of your turbo, But all in all it will take a lot of changes to your motor before you should even attempt to put a turbo on because stock compression puts heavy strain on your motor because it wasnt built for turbo. And go to the junk yard and get a tsi turbo or gsx/t turbo from eclipse or talon the gen 1s were bigger turbos and the gen2 was the t25s. I found a turbo for 100 dollars for my car outta a tsi but I scrapped that idea for an srt-4 swap. I am just waiting on my quote.
Old May 6, 2005 | 04:11 PM
SlowAssNeon's Avatar
SlowAssNeon
keep in mind of course, for the 1g dsms.. the automatics got the 13g turbo (which is bigger than the t25) while the manual trans got the 14b turbo.
while both are cheap options, i see no reason really to even bother trying to put either of those turbos on the neon, especially with a dohc, since you can find a used srt4 turbo for relatively cheap and it bolts right on.
Old Feb 19, 2007 | 01:36 AM
jblack's Avatar
jblack
anyone know about a ckeck valve
Old Feb 19, 2007 | 08:32 AM
racerx55's Avatar
racerx55
EDIT: derrf
What about a check valve? you cant push boost into you heater controls, brake booster, things like that, so you need a one way check valve on that stuff so they get vaccum only when your off the throttle.
Old Feb 19, 2007 | 11:58 AM
das2123's Avatar
das2123
Damn, this thread is old.
Old Feb 19, 2007 | 12:10 PM
spudsterier's Avatar
spudsterier
ORIGINAL: das2123
hey hey hey watch the language...just kiddin
Old Feb 19, 2007 | 12:57 PM
racerx55's Avatar
racerx55
yea i seen that after i replied, at least i wasnt the one to bring it back up from 2 years ago..
i just woke up so i dont pay much attention
