96 Neon Clicking in Dash
Old Feb 21, 2010 | 08:08 PM
jltreadwell's Avatar
jltreadwell
Default 96 Neon Clicking in Dash
When the doors are closed, dome light off, there is a clicking noise from behind the gage cluster. When I remove the gage cluster it stops. I pulled the fuse for the interrior lights and it stops. This is new, it started yesterday.
Old Feb 22, 2010 | 11:36 AM
bg1995redneon's Avatar
bg1995redneon
The clicking noise sounds like a typical relay. Pulling the instrument cluster and it quits indicates it is on that board, but off the top of my head I don't know what relay is on the cluster that could be the one. I assume that you put the cluster back in before you pulled the fuse, so it could also be a relay that is on that circuit.
Old Feb 25, 2010 | 01:26 PM
bg1995redneon
I was looking at the wiring diagram last night, but then I realized that I did not know for sure which fuse you pulled. You said interior lights, but I wanted to be sure. Can you give me the Fuse # of the one you pulled that stopped the clicking?
I assume that you put the instrument cluster back in with the fuse still pulled and the clicking did not return, but if not, try that.
Old Feb 27, 2010 | 08:22 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
sounds like the door switches are bad. I am not for sure if it matters with the doors closed or not, I know most commonly it
buzzes or Clicks" with the doors open though.
Old Feb 28, 2010 | 12:11 PM
itate's Avatar
itate
x2 on the door switch, mine clicked when the doors were closed.
Old Mar 1, 2010 | 08:03 PM
jltreadwell
My son took the car back to school. I will see him this week and will check the door switches. Thank you
