bad shaking in the front end!
Old Mar 18, 2010 | 06:18 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Originally Posted by Neongreg88
look and see if ur rotors and pads are good... somtime it will shake ad a speed over 45 and higher.. the rotors mit be worped and pads mit be junk and it could be ur alinement.. make sure ur tires are dont have flat spots and not a bad CAMBER
if the rotors were warped you would feel it in the brake pedal
Old Mar 18, 2010 | 06:19 PM
DOHCgarrett t3
Originally Posted by Ghost Neon 2
Makes me want to order the bushings kit that much more for my car. Do not have the vibrations, but that car pulls all over under hard launches. Would like as much control as possible.
if it pulls it is because one tire always pulls more than the other get an LSD
Old Mar 19, 2010 | 01:00 PM
Neongreg88's Avatar
Neongreg88
i had the same thing and i got a lsd it isnt as bad...
Old Mar 31, 2010 | 11:04 PM
Nuklhed074's Avatar
Nuklhed074
yeah i know this im a mechanic and the rotors would only do it under braking if their warped i think its because their cracked and busted up pretty bad and its causing a shacking cause of the rotating mass
