Where is the low pressure port?
Old Mar 23, 2010 | 01:36 PM
idolsidol's Avatar
idolsidol
Default Where is the low pressure port?
To recharge the air con with a canister.
A picture would help
Thanks
Old Mar 23, 2010 | 02:35 PM
thecause17's Avatar
thecause17
Passenger side near the fender. Generally the recharge kits will only fit one port anyway, they are two different sizes.
Old Mar 23, 2010 | 02:48 PM
idolsidol's Avatar
idolsidol
Thanks. Ill have a look.
Old Mar 23, 2010 | 03:21 PM
das2123's Avatar
das2123
And those recharge kits don't work very well either.
Old Mar 23, 2010 | 07:37 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
I had an issue with the recharge kits Das, but it was only because I over-filled it. Other than that I just had to recharge it every Spring. Guessing maybe because it had a leak?
Old Mar 24, 2010 | 05:38 AM
idolsidol's Avatar
idolsidol
I forgot to ask, the previous owner smoked in the car so i want to change the cabin filter. Where is it and how do i remove it? Thanks alot.
Old Mar 24, 2010 | 08:35 AM
das2123's Avatar
das2123
The gauges read correctly and showed it as full, but no cold air. Took it to my mechanic and he put the real gauges on it and added some more refrigerant and leak tested it, no problems.
The neon does not have a cabin filter. What you can do is put a small cup of vinegar in your car and make sure all the windows are closed. The vinegar will absorb some of the smoke smell as well as any other odors that may be lurking. Let it sit overnight.
Old Mar 24, 2010 | 01:34 PM
thecause17's Avatar
thecause17
I haven't had any trouble with the kits before. I've used the ones that Quest makes twice, including recently on the neon, and one other time on an F-150 with no issues. Of course if you have a leak its going to come back out, but they also sell the refrigerant with a stop leak included, which works good for small leaks. The canister i recently purchased also had the dye in it for finding leaks.
Old Mar 24, 2010 | 01:41 PM
das2123's Avatar
das2123
Could be the brand that I bought. I will look and repost later when I get home.
Old Mar 24, 2010 | 02:01 PM
thecause17's Avatar
thecause17
Yeah, I'm sure the quality on any of these kits' gauages aren't that great considering the cost, especially when put in comparison with a good set of HVAC gauges. You're looking at a minimum at $100 for a cheaper set of those gauges, and I've seen them out there for $250+. Worth it though if you're in the HVAC business. It's possible you just got a bad gauge.
