just want to make sure
Old Mar 23, 2010 | 08:28 PM
dirt neon's Avatar
dirt neon
Default just want to make sure
ok, so ive seen on here that you dont need the egr valve on the car for it to still run properly.. right? If so, can I make up peices to completely block the holes that are open where the pipe and the valve would go? just want to make sure before i waste my time burning out pieces for it. thanks
Old Mar 24, 2010 | 08:39 AM
das2123's Avatar
das2123
Correct.
Yes you can!
Old Mar 24, 2010 | 11:57 AM
bg1995redneon's Avatar
bg1995redneon
One very annoying problem of doing this is that your check engine light (CEL) will come on and stay on - unless you have a performance PCM that does not even have a check for EGR.
Old Mar 24, 2010 | 03:58 PM
dirt neon's Avatar
dirt neon
thanks, i use the car for dirt track racing so the cel wont really matter thanks though
Old Mar 25, 2010 | 01:53 PM
bg1995redneon
Then in your particular case, may I recommend removing the bulb so that you don't get distracted by it while racing and BTW - tear it up!
Old Mar 28, 2010 | 01:48 AM
Neongreg88's Avatar
Neongreg88
go on ebay they sell block off plates.....
Old Mar 28, 2010 | 01:50 AM
das2123's Avatar
das2123
Why? It is cheaper if he does it himself!
Old Mar 29, 2010 | 07:57 PM
dirt neon's Avatar
dirt neon
yea i burnt them out with a plasma at work. thanks for the help and hopefully i got this thing fixed ive been messing with it for about a year now so this sat i will know for sure if its fixed, first race of the season
Old Mar 30, 2010 | 07:42 AM
das2123's Avatar
das2123
Keep up posted with results and pics. Good luck.
Old Apr 3, 2010 | 10:36 PM
dirt neon's Avatar
dirt neon
ok just got home from the races and it sucked. practice went ok but i could tell that there is still something wrong so i go out for the race and the take off was great and then about 2 laps in and i start slowing up and the car just wont go any faster. Its like it gets to a certain speed and it just falls on its face, and then on lap 9 it started to cut out and pop and bogg down. I 've replaced all the sensors so I think the next thing to do is get another motor. Anybody have a motor or a parts car with a good motor for sale and live close to waynesboro, Pa?
