sohc
Old May 7, 2005 | 03:44 PM
Low_Rider's Avatar
Low_Rider
Default sohc
If i take off the Sohc plastic thing that runs to the air filter will this effect the engine? I assume that it just helps bring the air to the air filter but is it necessary? Will the moter just heat up? I plan on gettin a intake for it, are they easy to install?
Old May 7, 2005 | 07:28 PM
SlowAssNeon's Avatar
SlowAssNeon
Default RE: sohc
the part you are referring to is the snorkel. removing it doesnt help, nor hurt. it will make your intake sound louder tho. it offers no real performance gain however. id just leave it on there till you get a real intake
yeah, intakes are pretty easy to install.
Old May 7, 2005 | 11:02 PM
Low_Rider's Avatar
Low_Rider
Default RE: sohc
Tanks alot man, what if it was off and it was rainin would this effect it? Plus what is a good intake of a sohc auto? I mostly want something that will bost some hp but also look half decent.
Old May 8, 2005 | 12:27 AM
SlowAssNeon
Default RE: sohc
nah, with the snorkel off and it raining, you should have no problems. the filters location with the snorkel off doesnt change, and its pretty out of the way for water to get to it.. so long as the weatherstripping on the car directly above it is still there
good intake, sohc auto.. 1g.. iceman would be good, but i hate seeing people spend the $$ for an iceman only to have to cut it to fit the automatic.. so the "3.0 intake" would be my next suggestion. the 3.0 intake doesnt look the best tho, but it does perform.
theres no other intakes for the 1g neon that i would recommend. all the ebay "cold air" intakes just place the filter where the stock filter box is, and dont really add much for performance, so i feel theyre a waste of $$ personally.
Old May 8, 2005 | 12:39 AM
Low_Rider's Avatar
Low_Rider
Default RE: sohc
alright man thx for all the help, yeah i'll check out the 3.0 and iceman intakes thx
