BAD NEWS
Old May 8, 2005 | 04:35 AM
winddancer's Avatar
winddancer
Default BAD NEWS
WELL I CHANGED THE WATER PUMP AND TIMMING BELT PUT IT ALL TOGETHER AND TRIED STARTING THE ENGINE BUT IT SOUNDED LIKE IT HAD NO COMP. PULLED THE INTAKE MANIFOLD AND ON TDC I COULD SEE DOWN A 8 VALVES SO OFF TO PICK-N-PULL I WENT GOT A HEAD FOR $50 WITH GOOD VAVLES PULLED MY HEAD AND THE INTAKE VALVES AND ROLLED THEM ON THE CONCRET AND THEY LOOKED LIKE A HOT WHEEL WITH BENT WHEELS THE EX. SIDE LOOKED OK BUT SHOULD I STILL CHANGE THEM SINCE I HAVE THE HEAD OUT OR NOT ANY SUG.
Old May 8, 2005 | 02:00 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: BAD NEWS
Did the timing belt advance on broken teeth or something cuz i dont think the waterpump and the overheating would cause the valves to get bent or warped...
Old May 8, 2005 | 02:12 PM
highrevr/tflea
I would change the ex side better safe then sorry....You are confusing me, do u have a new head or not? If not you need to rehone cylinder walls and check for warping...
Old May 8, 2005 | 02:47 PM
winddancer's Avatar
winddancer
the timing belt striped that is what bent the valves i got a used head the blck looks good but i trust mine more so i am changeing them over i am woundering how offten the ex. valve get bent
Old May 8, 2005 | 09:36 PM
winddancer's Avatar
winddancer
all right update for those out there that care i found i set of ex. valves bad and installed all the good valves in my head BOY I DO NOT WANT TO DO THAT AGAIN INSTALLING SPRINGS IS NOT FUN IT TOOK ME 4 HR TO DO 10 VALVES now i have to wait for ne head gasket and intake gasket becuse auto zone dont have the intake so i just orded both more updates later
Old May 9, 2005 | 11:02 AM
SlowAssNeon's Avatar
SlowAssNeon
tell me about it, changing them valve springs in the neon heads (both sohc and dohc) is quite a pain. i believe it took me 2-3 hrs last time i did some on a sohc head.. turns out my c-clamp style compressor is slightly bent, making the job a tad harder than it should be.
yeah i was gonna say that generally if the intake valves are bad, the exhaust ones are too.
how did the pistons look? scratched up or just fine?
Old May 10, 2005 | 04:32 AM
winddancer's Avatar
winddancer
this is what i had to do the job with
a guy i work with had me bring the head over and we laped the valves and found all the exhaust vavle were bad so we changed them it took 4 hr to do it all 15 min to set the valves so now all i am waiting for is the gaskets and i have a empty shell head
[IMG]local://upfiles/15202/B8C1A9D807154881B840F9B5C7075DD0.jpg[/IMG]
Old May 10, 2005 | 04:38 AM
SlowAssNeon
ORIGINAL: winddancer
how the heck did you get that to work on the neon?? i had one, and no way would it fit in the neon head! kept hitting the walls of the head
Old May 10, 2005 | 10:41 PM
winddancer's Avatar
winddancer
it works it takes a long time and even longer when they are bent it was a pain
Old May 10, 2005 | 11:19 PM
highrevr/tflea
How the hell did u get that puller to work?!!
