Quick question
Old 05-27-2010 | 03:48 AM
Chicken91's Avatar
Chicken91
Default Quick question
Hey guys, i know this is gonna sound dumb, i'm kinda tryin to learn some things about engines, and i recently bought a 1999 dodge neon sport and was wondering if it can handle any psi stock? because a buddy of mine thinks it can handle 5 without completely boring the cylinders and getting new pistons, rings, etc. but im just not sure.
Old 05-29-2010 | 07:39 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
huh, are you sayin your trying to turbo the engine than 5psi is fine. you can actualy run up to 8psi on stock internals. after that you may want to upgrade your fuel injectors fuel pump and pistons and rods. if you turbo use the stock PCM
Old 06-03-2010 | 09:23 PM
Chicken91's Avatar
Chicken91
ahh, alright, thank you, i think i will run that for a while until i can get money to re-do the internals then, then after that kick er up a lil bit. thanks again
Old 06-03-2010 | 11:55 PM
neoncrazy101's Avatar
neoncrazy101
BEFORE you do anything, get a compression check and leak test. When you turbo it, the extra PSI will make any leak an even bigger leak A LOT sooner.
Quick Reply: Quick question
