Stratus 2.4l engine
Old Jul 13, 2010 | 08:40 PM
ottoretto's Avatar
ottoretto
Default Stratus 2.4l engine
hi everyone!... i wanna know how many mm. or inches can be milled (shaved) in a 2.4 engine, from a stratus, i just want to get a really high compression ratio!....
Old Jul 13, 2010 | 09:20 PM
sapporo's Avatar
sapporo
you need to measure the piston to deck height. then how thick the head gasket is. you can have the block decked so the piston is out of the hole but has .025" min clearance to the head.
you can also mill the head. but be aware that when you mill the head and block, you will need to advance the cams as milling causes the cams to retard timing
Old Jul 14, 2010 | 04:40 PM
ottoretto's Avatar
ottoretto
Yeah i know all that!... but this engine have a piston that the dome reach the block deck.... the dome has a 0.25" of height, and i just want to know if i can mille that o a lil less to the block, just for make higher compression!...
Old Jul 14, 2010 | 07:09 PM
sapporo's Avatar
sapporo
you can mill .060" off the block no problem.
Old Jul 14, 2010 | 09:46 PM
ottoretto's Avatar
ottoretto
oh!... that is sumthing! but what is the most height i can mille? no matter the risk hehehe
Old Jul 14, 2010 | 09:57 PM
sapporo's Avatar
sapporo
.060 off the block and .150 off the head but you'll really need to check the valve to piston clearance... cuz there's no room for error at that point
Old Jul 14, 2010 | 10:42 PM
ottoretto's Avatar
ottoretto
oh!! that is a lot for the head.... i wanted to keep the head without any shave... that why i asked about the block... a head if you shave it a lot, if the car overheat say goodbye to the head... and about clearence dont worry i know what i have to do.. im just curious, cuz i dont know anything of this block
Old Jul 14, 2010 | 10:52 PM
sapporo's Avatar
sapporo
IDK we take off .180-.200" off a certain head (non-mopar) to get compression ratio upwards 14:1
Old Jul 15, 2010 | 01:47 PM
ottoretto's Avatar
ottoretto
OMG..... but wich head??... i think the most for a mopar head is 0.080" or 3 mm.... wow 14:1 on 2.4l is awsome... i need to check about the block ¬¬ xD
