Fuel pump fuse keeps blowing !!
Old Jul 19, 2010 | 09:00 PM
dvanhorn's Avatar
dvanhorn
Default Fuel pump fuse keeps blowing !!
Fuel pump fuse keeps blowing, can I bypass the old wire from the power control to the fuel pump? Any ideas what it can be?
Old Jul 19, 2010 | 09:21 PM
sapporo's Avatar
sapporo
sure you can just bypass it
my idea is you have an abnormally high amount of current going through the circuit
Old Jul 19, 2010 | 10:22 PM
dvanhorn's Avatar
dvanhorn
I'm thinking the power wire from the fuse back has a short and is killing the fuse. I think I'll test it tomorrow with the multi meter to see if the current is open or not. Going to test it from the pump end.
Old Jul 20, 2010 | 08:28 AM
sapporo's Avatar
sapporo
i think your right. but it's pretty rare for that to just magically happen without some event taking place to mess it up.. like some rookie hacking in a stereo or doing some off-roading
Old Jul 21, 2010 | 09:39 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Check the down stream o2 sensor that has a tendancy to melt and ground out on the exhaust
Old Jul 27, 2010 | 08:10 PM
dvanhorn's Avatar
dvanhorn
Just got around to checking it today. Started with the O2 sensor as recomended by DOHCgarrett t3. Guess what I found skined up bare wires taped them up and put a fuse in and it fired right up. Thanks a bunch I would have wasted alot of time trying to find that. Going to do a good fix on it before I start driving it.
Old Jul 27, 2010 | 11:15 PM
DOHCgarrett t3
Not a problem you can thank Das and Spud for teaching me to look there.
