sohc to dohc
Old Aug 2, 2010 | 07:10 PM
jokerfire's Avatar
jokerfire
Default sohc to dohc
can i put a dohc on my sohc block what is the good and bads of it please help thinking about doing this
Old Aug 2, 2010 | 07:15 PM
jokerfire's Avatar
jokerfire
or should i just get a doh block and use it with the sohc
Old Aug 6, 2010 | 08:17 AM
Ghost Neon 2's Avatar
Ghost Neon 2
The sohc and dohc block are physically the same. The difference is in the pistons. Stock sohc pistons are flat, while stock dohc pistons are domed for a bump in compression.
The stock dohc head flows more air than the sohc, which is the obvious choice in the "bang 4 buck" department. What is your build plan?
Old Aug 7, 2010 | 11:46 AM
jokerfire's Avatar
jokerfire
i just wanted to know was thinking about more power in a sleeper way
Old Aug 10, 2010 | 01:00 PM
das2123's Avatar
das2123
Stock vs stock, the actual HP difference isn't much from the SOHC engine vs the DOHC engine. The DOHC head (engine) has more modding capability though.
