kinda new
Old Nov 14, 2010 | 02:30 PM
koidog10's Avatar
koidog10
Cool kinda new
Been on before about a year ago
now have a1998 neon with a problem.
the blower motor for the ac/heater fuse keeps blowing
i do not know if the motor went out or if its somthing else.
please help thanks
Old Nov 14, 2010 | 03:01 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the first generation Neon section,
FF
Old Nov 14, 2010 | 05:30 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
check for loose or damaged wires first then Try swaping the blower motor, the motor may be on its way out.
Old Nov 14, 2010 | 06:52 PM
koidog10's Avatar
koidog10
I will do that need to know is the motor behind the switches or where
and how hard is it to get to. Can i get a wiring diagram from the internet to tace the wires thanks koidog
Old Nov 14, 2010 | 08:04 PM
DOHCgarrett t3
the motor is on the passenger side. above the feet area. should be a green and black wire attached to it. a few 8mm screws hold it in. It is kind of a Pain in the *** (PITA) to get out. but it can be done might help to remove the Kick shield on the side there and then pull the carpet back a bit to remove the motor.
How often does this fues blow, Does it happen after a few min of running, off and on, or as soon as you turn on the heat/AC? as for a wireing diagram I don't think so, maybe if you look in the chiltons or haynes book.
Old Nov 14, 2010 | 11:05 PM
koidog10's Avatar
koidog10
the fuse blows as soon as you turn it on
thanks.
Old Nov 15, 2010 | 12:33 AM
DOHCgarrett t3
well lets try this, Hop under the passenger side floor board and unplug the motor and replace the fuse, turn on the motor and see if the fuse still pops. If it still pops I am going to assume the wireing is to blame. if it does not blow, you can test the motor by hooking up a 12v battery charger to the motor.
How i did this once to test a window motor was to take the leads from a volt meter and inserted 2 drywall screws in the female ends and took the battery charger clamps and placed them on the screws. took the pointed leads and placed them on the motor pins. Yes, its a bit of ghetto engenering but it worked.
Old Nov 16, 2010 | 08:20 AM
koidog10's Avatar
koidog10
Thanks DOH it ended up being the motor it was not that bad taking it out
thanks again for the info koidog
