radiator problems.
Old Nov 26, 2010 | 09:27 AM
IRISH_R/T's Avatar
IRISH_R/T
Default radiator problems.
I have a 99 dodge neon r/t dohc. My radiator decided it was time to split. So now I have to replace it and I know my way around a car pretty good and the guy at advanced asked where my condenser was located? Does this really matter or is this guy trying to get me to buy a more expensive radiator??
Old Nov 26, 2010 | 07:48 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
tell him it is in the same spot on all Neons but the A/C condencer coil is attached to the radiator via bolts. once you replace the radiator you will have to get some more R 134a to replace what you have lost.
Old Nov 30, 2010 | 10:06 AM
IRISH_R/T's Avatar
IRISH_R/T
Yeah the condenser attaches to the front of the radiator via bolts that go through a bracket into the top of the radiator. Both the 149 and the 89 dollar radiators had those holes in the exact same location. I do not think that I lost anything from the a/c condenser, the radiator just cracked on the bottom and needed replaced.
Old Nov 30, 2010 | 03:05 PM
hemi4spd's Avatar
hemi4spd
you can remove the condensor from the rad without loosing any refrigerant,
wire it up so it doesnt hang by the hoses once the rads removed
