rocker arm installation
Old Jun 19, 2005 | 06:26 PM
xdeathwishx's Avatar
xdeathwishx
Default rocker arm installation
when i put the rockers back on the head, they dont sit level due to the position of the lifters. How am i supposed to fasten the bolts down?
Old Jun 20, 2005 | 03:29 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: rocker arm installation
cant u turn your crank? Ur cylinder head is on the engine, right. Your not sposed to tighten until its attached or so i would think.
Old Jun 22, 2005 | 12:04 AM
xdeathwishx
yeah i figured that out now. you just put it back on the engine, turn the crank to 3 notches before tdc... and torque the bolts. this way only one rod will actually lay flat... but the lifters is whats holding the other from staying flat. so you just torque the bolts, and the lifter is kinda like a spring or spring loaded for lack of a better explanation. hwen you tighten them, they end up laying flat. My dad had to explain this one to me. Im new at internal engine work. ive swapped a million sr20's(nissan), but never actually ripped one open.
Old Jun 22, 2005 | 01:14 PM
highrevr/tflea
hehe i gotta SR20 sittin in my driveway right now...lol
Old Jun 22, 2005 | 03:15 PM
xdeathwishx
is it the sr20det? black top or redtop? I used to live in japan, i had the nissan silvia s14, which is the jap version of the 95 and newer 240sx. it had a blacktop sr20det. that engine was bulletproof. cost me 500$ from a junkyard.
Old Jun 22, 2005 | 11:22 PM
highrevr/tflea
anodized top/ N/A not a det just a de.
