dohc engine questions
Old Feb 14, 2011 | 12:54 PM
cuwa's Avatar
cuwa
Default dohc engine questions
I know this has probably been asked before but here we go. I have a 98 DOHC neon and I can get a good deal on stock pistions , connecting rods and cam for a SRT-4 neon can they be installed in the 1st gen neons?
Old Feb 14, 2011 | 09:27 PM
Ghost Neon 2's Avatar
Ghost Neon 2
2.4L connecting rods and piston will not work in a 2.0L block.
If you doubt, spend the money and see for yourself.
Old Feb 15, 2011 | 06:33 AM
22DODGE22's Avatar
22DODGE22
The rods can be installed IF you get custom made pistons. The best thing to do is research the dimensions of things like rod length, piston compression height.
Old Feb 16, 2011 | 09:28 AM
Ghost Neon 2
For the cost of custom pistons, one could source out the connection rod from a 2gn magnum neon. They are made of the same material as the connecting rods used in the srt, and are just as strong.
Old Feb 16, 2011 | 08:09 PM
22DODGE22's Avatar
22DODGE22
I found some Honda pistons that might work with the 2.4 rod in a 2.0 block. Same bore, same piston pin diameter but shorter compression height.
