head swap
Old 07-13-2005 | 11:58 PM
neon1985's Avatar
neon1985
Default head swap
i've been reading up on putting a dohc head on a sohc block and was just wondering what is the averge horsepower rating for a sohc neon with a dohc head?
Old 07-17-2005 | 11:13 AM
RadarLove's Avatar
RadarLove
Default RE: head swap
Just head swap? Stock SOHC pistons? You lose about 0.5 points on compression (larger combustion chamber), so figure 125ish flywheel HP.
Old 07-27-2005 | 11:00 PM
neon1985's Avatar
neon1985
that sucks.....................
Old 07-28-2005 | 12:09 AM
casper's Avatar
casper
A stock 1st gen SOHC is 132, if all you do is swap the head to a DOHC, you will probally get 120hp. You need to swap the PCM and pistons too.
Old 07-28-2005 | 09:03 PM
95neonracer's Avatar
95neonracer
From the looks of it, what is the point of doing the swap then?
Old 07-28-2005 | 09:37 PM
casper's Avatar
casper
ORIGINAL: 95neonracer
There is a point to it. A DOHC gives you 150hp. It would be easier to just pick up a good DOHC and drop it in.
Old 07-28-2005 | 09:50 PM
95neonracer
I may be misunderstanding it but isn't 120 less than 132???
Old 07-28-2005 | 09:57 PM
casper's Avatar
casper
Yeah, the pistons are different and if you use SOHC pistons you will have less compression than with DOHC pistons. And it won't run at all with a SOHC PCM.
Old 07-31-2005 | 01:05 AM
neon1985's Avatar
neon1985
yeah i figured that i was just looking for a quicker way around the swap but oh well the whole engine it is!!!!!!!!!!!!!
Old 07-31-2005 | 03:57 AM
casper's Avatar
casper
ORIGINAL: neon1985
Its just easier.
Quick Reply: head swap
