2.4l swap, worth it?
Old Aug 3, 2011 | 07:06 PM
mham0711's Avatar
mham0711
Default 2.4l swap, worth it?
so i have the 99 dohc expresso. i am interested in the 2.4l swap or possibly the srt swap. is it worth it? or should i just mod my dohc?
Old Aug 3, 2011 | 07:59 PM
darthroush's Avatar
darthroush
Section Moderator
Usually by the time an SRT swap is done and complete, you're better off just buying an SRT. Don't know about a standard 2.4 swap. Not sure what all is required for that.
Old Aug 4, 2011 | 12:34 AM
das2123's Avatar
das2123
The 2.0 and 2.4 have the same head. The difference is the block. You get added torque with the 2.4 and can be modded more to get more power out of it.
Is it worth it? That's up to you. What is your budget and HP goal for the car?
Old Aug 4, 2011 | 10:57 AM
mham0711's Avatar
mham0711
right now im not super worried about budget. I am just looking to go fast. and eventually turn it into a show car that can back itself up
Old Aug 4, 2011 | 11:28 AM
das2123's Avatar
das2123
I would personally get a 2.4 and build it up with SRT-4 internals. It is much easier to swap in the 2.4 than the SRT-4 engine. You can run the 2.4 with your stock PCM (with some work) as opposed to getting an SRT-4 PCM that hasn't seen sentry or upgrading to a Stage 1 PCM.
Old Aug 4, 2011 | 03:28 PM
mham0711's Avatar
mham0711
so if i do just get a 2.4 and upgrade it what pcm do you recomend
Old Aug 4, 2011 | 03:41 PM
das2123's Avatar
das2123
The AF/x race PCM would be the best one to use. Second would be the AF/x Street PCM and then the Mopar Performance PCM. These are all discontinued, so you will have to search forums to find a used one.
Old Aug 4, 2011 | 04:22 PM
mham0711's Avatar
mham0711
and the AF/x works with a manual?
Old Aug 4, 2011 | 04:28 PM
das2123's Avatar
das2123
Yes it does.
Old Aug 4, 2011 | 04:45 PM
mham0711's Avatar
mham0711
where do you purchase from? i googled and didnt find anything
