A Mystery.. 98 Neon
Old Jul 22, 2005 | 02:24 AM
Macloed's Avatar
Macloed
Default A Mystery.. 98 Neon
Hi All,
My 98 Neon has AC exceleration issues. I changed the PCM 3 times now and still speeds up when on to aprox 40 mph.
Can it be a bad compressor???
Are there any other parts that can be feeding bad fuel info to the PCM to make car excelerate???
MAC
Old Jul 22, 2005 | 10:15 AM
AmericanCRacer's Avatar
AmericanCRacer
Default RE: A Mystery.. 98 Neon
Well Macloed, I have sort of the same problem. If I have on the defrost or AC on "sometimes" the idle will jump up to around 2 grand, or in my case it wont fall past 2000 rpm's when I let off the gas.
It has had me puzzled for almost 2 years. It cannot be the compressor becouse mine has no belt on it.
I thought that maybe that becouse I took my belt off it does it but I dont know.When you do get it straight let me know! GOOD LUCK!!!!!!!!
Old Jul 22, 2005 | 04:00 PM
casper's Avatar
casper
what do you mean by accelerate? Do you mean just a high idle, if so how high?
Old Jul 23, 2005 | 03:07 AM
Macloed's Avatar
Macloed
Its high Idle. But if i take foot off break at a light it can go up to 35-40 mph idle. That goes for heat or a/c. If i turn it off idles fine.
MAC
Old Jul 25, 2005 | 08:27 AM
RadarLove's Avatar
RadarLove
Sticky IAC would be my bet.
Old Jul 26, 2005 | 02:52 AM
ATL Neon's Avatar
ATL Neon
ORIGINAL: Macloed
Do you mean it will go up to 35-40 mph without touching the gas?
Old Jul 26, 2005 | 02:25 PM
Macloed's Avatar
Macloed
Yes without touching Gas...
MAC
Old Jul 27, 2005 | 06:16 AM
RadarLove's Avatar
RadarLove
With the A/C or defrost on, the PCM sends a signal to the IAC (Idle Air Control) valve to compensate - opens more to allow more air in. If it is sticky or otherwise failing (common enough), it will stay open longer than it's supposed to, which keeps rpm's up. So like I said, sounds like a sticky IAC.
