1997 DOHC Neon died while driving
Old Nov 26, 2011 | 02:22 PM
97Purp's Avatar
97Purp
Default 1997 DOHC Neon died while driving
Like the title says. I was driving then the engine shut off. Tried restarting and it turns over, I can hear the the fuel pump pump. Just doesn't fire at all. I am assuming there isnt spark. I switched out the cam position sensor hoping for some good luck. Not so much. The timing belt is still there, i peeked in the access on the cover. I tried spraying some starting fluid in the TB but that didn't seem to work either.
Old Nov 27, 2011 | 06:33 AM
XxneonfreakxX's Avatar
XxneonfreakxX
I had somethin similar like that happen to my 96 neon. After looking through everything it ended up bein as simple as the ignition fuse not bein in all the way. Runs just fine now.
Old Nov 27, 2011 | 10:52 AM
97Purp's Avatar
97Purp
where would that be located? the only other thing i can think of is the crank position sensor. I checked the fuse box under the hood all were fine...
Old Nov 28, 2011 | 06:34 AM
XxneonfreakxX
Its in your regular fusebox next to the driver side door. Theres a little panel u pull off and on the back of that panel it tells ya where the ignition fuse is. Hopefully this helps. It could be the cps but i dont think it would start to begin with if it was that but i could be wrong
Old Nov 28, 2011 | 06:39 AM
XxneonfreakxX
My buddy had this happen to his 99 bonneville and it happened to be his battery cables to the terminals. His is sidemounted tho and he had a stripped thread. 1st gen neons are top mounted( thus harder for something like that to happen) but its another thing to look at if ya havent yet. Something like this could be a lot of things however it sounds like its something electrical if it turns over and the fuel pump is registering.
Old Nov 28, 2011 | 12:17 PM
97Purp's Avatar
97Purp
Well i said teh hell with it and replaced the crank sensor. That aint it either. All the fuses check out, battery connections are good... Time for a garage to look at it i think. Damn car!
Old Nov 28, 2011 | 12:27 PM
das2123's Avatar
das2123
Have the battery checked first.
Old Nov 29, 2011 | 07:04 PM
Ghost Neon 2's Avatar
Ghost Neon 2
What are the symptoms? Does the car start up now? Do you hear a buzz from the fuel pump before trying to start the car?
Do the easy stuff before turning it over to a garage.
Old Nov 29, 2011 | 10:55 PM
Neon-Jeep-Dart's Avatar
Neon-Jeep-Dart
make sure the plugs, wires, and coil are good... thats your spark... battery is good to check, same with alternator, but spark are confined to certin things... are you sure it isnt fuel delivery????
Old Dec 1, 2011 | 12:31 PM
97Purp's Avatar
97Purp
The plugs and wires are new. The coil as well. It isnt fuel delivery, the car wouldnt even sputter even when i shot some starter fluid in it while cranking it over. The battery is fine as well.. Starting to look like maybe it is the timing belt... Since it died , i noticed it is turning over quicker than it used too...*crosses fingers* I hope it isnt tho, i cant afford a new top end ..
