I have a 96 dodge neon and am wondering how i can fix the hesitation in acceleration. I can floor the throttle and it will hesitate about 4 seconds before finally kicking in. I have tightend the throttle linkage cable so there isnt any slack as well as reducing the slack on the throttle cable connected to the end of the gas pedal so the throttle body opens more when floored, however not much change. any suggestions?
I swapped it with the #1 wire and the wire goes in fine and then i looked at the #4 plug and the tip is broken off so the boot isnt sliding on. But wouldnt that mean my engine is running on 3 cylinders? Is that possible with an inline 4?
