what kind of trans should i use?
Old Dec 18, 2011 | 10:10 PM
19base95's Avatar
19base95
Default what kind of trans should i use?
Let my friend use my car first mistake cuz it came back on a tow truck. Didnt pull the trans yet but im pretty sure it needs one you can see something popped a hole in the case. im wondering what would be the best setup to use. i plan on running a mild turbo set up in the summer
Old Dec 19, 2011 | 11:33 AM
das2123's Avatar
das2123
Use the 3.55 tranny. They are better for turbo neons.
Old Dec 19, 2011 | 04:49 PM
19base95's Avatar
19base95
Do you kno what trim neon they cam in?
Old Dec 20, 2011 | 11:19 AM
das2123's Avatar
das2123
The 3.55 came in all SOHC neons, with the exception of the ACRs.
Old Dec 20, 2011 | 02:17 PM
19base95's Avatar
19base95
What do you think would be my best route as far as boosting a sohc?
Old Dec 20, 2011 | 02:43 PM
das2123's Avatar
das2123
It will all have to be custom as there are no more aftermarket kits for the neon any longer. You may find a used kit on ebay or other forums, but you won't find a new one. One easier route would be to swap a DOHC head on your car and use the SRT-4 turbo as it bolts directly to the head. Of course, there is much more involved but that is the quickest and one of the cheaper routes to go.
Old Dec 20, 2011 | 09:50 PM
19base95's Avatar
19base95
Will I have a problem finding parts if I swap to the dohc head?
Old Dec 20, 2011 | 09:52 PM
das2123's Avatar
das2123
You shouldn't. If so, let me know and I can help you out. Read the sohc to dohc head swap from the stickies up top.
Old Dec 21, 2011 | 03:41 AM
Ghost Neon 2's Avatar
Ghost Neon 2
May want to consider a 2.4L engine...
Old Dec 21, 2011 | 08:10 AM
19base95's Avatar
19base95
i was considering the 2.4 swap but how much of the sohc wiring harness will work. ive heard its fairly easy if your swapping it with a dohc
