rear wheel noise
Old Jan 2, 2012 | 07:55 PM
RebelX's Avatar
RebelX
Default rear wheel noise
got a 98 neon expresso
i have a weird noise coming from the right rear tire. its not the struts, although those are getting old.
its almost a grinding/whining when driving, but not a constant noise, seems worse on a left turn. i have allready checked the bearing hub assembly for any play at all and did not find even the slightest budge in slop as i call it.
i had to back off the e-brake shoes as they seemed to be rubbing hard and that helped with the grinding, but im really starting to question the calipers/rotors. i had to replace the front rotors this summer as they stuck on me. wondering if the rear ones are starting to do the same now.
heres a sound clip of what it sounds like in my garage for the grinding
Old Jan 5, 2012 | 03:08 PM
das2123's Avatar
das2123
What about the strut mounts? How do they look?
Old Jan 5, 2012 | 08:45 PM
RebelX's Avatar
RebelX
Ya know. I forgot to check those. I plan to do the brakes anyways now since ive had the car 4yrs n never touched the rear brakes
