95 cam?
Old Feb 13, 2012 | 09:50 PM
95neon1025's Avatar
95neon1025
Default 95 cam?
What is the actual benefits of putting a cam from a 95 in a different neon? just to let you know i have a 98 sohc i have a 95 cam and just want to know if it is worth it?
Old Feb 14, 2012 | 11:15 AM
das2123's Avatar
das2123
It is dyno proven to add ~3 to ~5 HP.
Old Feb 14, 2012 | 04:54 PM
95neon1025's Avatar
95neon1025
so its not like a huge upgrade and do u think its really worth it?
Old Feb 14, 2012 | 04:57 PM
das2123's Avatar
das2123
To do just the cam swap, probably not. But if you are doing some work where you take the timing belt off or something like that, then yeah its worth it.
Old Feb 22, 2012 | 05:59 AM
Trialmaster's Avatar
Trialmaster
I have a 95 head, I'm working on. Doing some light exhaust porting. Smouthing out the step under valv seats and polishing the port.
Cause of budget, I want to reuse the cam, but will that take benefits of the headwork, or should I go for a #Crane 12?
Exhaust Valve port before work.
Some work I have done.
Old Feb 22, 2012 | 08:52 AM
das2123's Avatar
das2123
I would go with the Crane #12 since you are doing the headwork. You can get anywhere from $40-$70 for the stock 95 cam.
Old Feb 22, 2012 | 10:48 AM
Trialmaster
Thanks
What do you thing think about my headwork so fare?
Old Feb 22, 2012 | 11:21 AM
das2123's Avatar
das2123
Not bad.
