HELP!! NEON NOT STARTING STILL!!!
Old Aug 10, 2005 | 06:17 AM
R34TuRbOnEoNbOy's Avatar
R34TuRbOnEoNbOy
Default HELP!! NEON NOT STARTING STILL!!!
Ok i did a post a long time ago about my car not starting...Ok i put a new clutch in my car and and a new starter at the same time... when i went to go start the thing it just turns and turns....i come to find out that the crankshaft sensor connector had its wires pulled out so i put a new connector on sensor so it should be good... but it still is not starting...I did a voltage test on the coil and i am not getting any voltage into the coil.....need help i have been workin on this car for like the last two months and im starting to get mad!!! Its my turbo neon and I miss the speed....need help..I have a car show in two weeks and have to drive it there...so i dont care if you are just guessing, just throw any idea at me..thanks
[IMG]local://upfiles/8801/C5AB8D2939EC4FD6A466552E4C668AD2.jpg[/IMG]
Old Aug 10, 2005 | 11:12 AM
catman22's Avatar
catman22
Default RE: HELP!! NEON NOT STARTING STILL!!!
ok so what exactly do you mean by "I did a voltage test on the coil and i am not getting any voltage into the coil"
did you chech the coil resistance while it was off of the car? or did you chech the connector to the coil while cranking to see if it was getting a signal? becaus i had the connector go bad on me before.
Old Aug 10, 2005 | 06:32 PM
R34TuRbOnEoNbOy
I have a voltage meter and i put positve end in middle prong of the connector for the coil while the engine was on....but i didnt do it while it was cranking.....
Where are the missing links and the fusible links on my neon...want to know if they could be a part of it?
Old Aug 10, 2005 | 07:26 PM
catman22's Avatar
catman22
using a test light connected to the positive battery terminal probe the two wires for the coil pack ( dark blue /tan black/ grey)while a friend cranks the engine DO NOT TOUCH THE DARK GREEN/ ORANGE WIRE OR YOU COUD DAMAGE THE PCM. while cranking the test light should blink rapidly, if there is no flashing the computer (PCM) is probibly shot but i would trace the wires back to the pcm and retest them there to see if there is a break in the wires.
Old Aug 11, 2005 | 02:42 AM
casper's Avatar
casper
ORIGINAL: R34TuRbOnEoNbOy
If you didn't do it while cranking you are not going to get a signal.
Old Aug 11, 2005 | 04:51 AM
streetbikr600's Avatar
streetbikr600
how a bout getting a pair of jumper cables and ground it to the motor and place the positive on the starter
Old Aug 11, 2005 | 05:55 AM
R34TuRbOnEoNbOy
Is there a main fuse for the crank and the camshaft?????
Old Aug 12, 2005 | 01:27 AM
99plymouth_neon's Avatar
99plymouth_neon
i have the same problem. wouldnt start, no spark. i did everything i could, changed everything. i finally broke down and took it to a shop. is your car reading code 11? well good luck i had hell with it.
Old Aug 13, 2005 | 04:36 AM
R34TuRbOnEoNbOy
I have a flashing check engine light but i havent got a code reader to check it......What was the problem with your neon...yeah im about ready to take mine to a shop but it wont start to get it there and my other car is a BMW and it doesnt have a tow hitch(hahaha yeah right) Im getting a new wiring harness for my car...and maybe a new PDC...
Old Aug 13, 2005 | 05:54 AM
99plymouth_neon
well my car is still in the shop right now so i still dont know what it was. i changed everything i could the crank sensor, cam sensor, timing belt, coil pack, harness, pcm, map/ait sensor just about everthing that controls the ignition. 275 dollar coputer didnt fix it.... you can read the codes off the check engine light. turn the key on, off, on, off, then on and count the flashes. it should flash one digit then pause and flash the other digit. a long pause will be between each code..... code 55 is just the "end of codes" code. mine read code eleven, which is basicly a loss of crank sensor, cam sensor, or slipped timing belt. but i changed them all and it still read it. the guy working on it hasnt had time to work on it just yet but he probably will start on it tomorow so when, or 'if' it gets fixed i will tell you what it was. good luck
