water on the back floorboards
Old Aug 14, 2005 | 01:54 PM
iloveGOLD's Avatar
iloveGOLD
Default water on the back floorboards
my girlfriend just bought a 95 neon and a couple dayz later she realized that there was water covering her back floorboards. she got it up and it came back. no ones spillin any drinks in there and her windows arnt open when it rains. it hasnt even rained yet! what could be the problem? thanx
Old Aug 14, 2005 | 03:11 PM
casper's Avatar
casper
Default RE: water on the back floorboards
Check your trunk and tail light seals, that is most likely where its comming from. It is a common neon problem.
Old Aug 14, 2005 | 07:13 PM
iloveGOLD's Avatar
iloveGOLD
i found lots of water in the spare tires compartment. im guessin thats the problem, now how do i solve this?
Old Aug 14, 2005 | 10:30 PM
catman22's Avatar
catman22
get some clear silicone and fill the gaps above and around the tail lights, that should solve your problem.
Old Aug 14, 2005 | 10:57 PM
casper's Avatar
casper
ORIGINAL: iloveGOLD
Find out where its comming from, It could be the tail lights or the trunk seal. If its the tail lights, there is a foam gasket between the lights and the car, either get new gaskets, or use the expandable foam insulation that they sell at home depot in a can. If its the trunk just order a new seal.
