alignment
Old Jul 23, 2012 | 12:33 PM
ohioguru's Avatar
ohioguru
Default alignment
im lowering my car with megan springs and no shop will touch it without the alignment spec sheet printed out for them. so can someone post a link ? also do i need the factory alignment specs or is there going to be another set since the car will be lowered?
Old Jul 23, 2012 | 01:04 PM
ohioguru's Avatar
ohioguru
also i have the rear camber adjust bolts installed. will i need any other parts to get this aligned properly.
Old Jul 23, 2012 | 06:36 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Align it to factory specs. If you have rear adjustable suspension make sure you tell them to do a 4 wheel alignment. Set the rear to factory settings before you go.
Old Jul 26, 2012 | 02:09 PM
das2123's Avatar
das2123
The dealer can give you a print out of the factory specs. You might want to add a little negative camber to help with corners. ~-1° is good on all four tires.
Old Jul 26, 2012 | 02:27 PM
I_Ride_Neon
Agreed! This is not uncommon.
Old Jul 26, 2012 | 02:28 PM
das2123's Avatar
das2123
And a lot more fun
Old Jul 26, 2012 | 08:58 PM
I_Ride_Neon
Post
And a lot more fun
Just to think 5 or 6 years ago I would look at the honda guys funny when they asked me to do this, sometimes it would be a bit more then 1. But I started to hear about it more and more. You usually only hear it from people that know what they are doing . And now I also tweak mine to my liking, usually takes me 7-8 tries before I am happy. Well until I left Midas. Something to the OP, be sure to get your print out and take a peak at it.
