my temp guage is reading hot even when the key is at on postion with motor not running has anyone else had this problem? is it a bad temp sensor or solder points or short wat is it ??
When the key is on, the gauge reads as it should. Either the car is overheating, you have a bad temp gauge, cluster is on the fritz, or the wiring is messed up.
