Sohc crane 12 1/4 mile times?
Old Sep 12, 2012 | 09:00 AM
  #31
Trialmaster's Avatar
Trialmaster
What about a dohc mtx pcm from same year?
I have one on hand for 120 bucks
Old Sep 12, 2012 | 01:29 PM
  #32
I_Ride_Neon's Avatar
I_Ride_Neon
It may give you a few more ponies. But I would hold off for something you can tune. I wish they could chip and flash the stock ecu's like they do with the older dodges... Oh well.
Old Sep 12, 2012 | 02:14 PM
  #33
Trialmaster
Used my Garmin Ecorouter to day. There I have all my sensors on my smartphone.
My throttle posision sensor, stays at 13% at idle, and 75% at full throttle. It goes alle from 1200 rpm to idle. I feel its something wrong here. This come up after I swapt to 60mm Mpx.
Old Sep 12, 2012 | 02:18 PM
  #34
Trialmaster
I ment, goes slow from 1200 rpm to idle
Old Sep 12, 2012 | 02:31 PM
  #35
Trialmaster
I bought that dohc computer. Have some more timing and rpm
They dont come around that often, here in Norway.
Old Sep 12, 2012 | 05:54 PM
  #36
I_Ride_Neon
Its normal for it to not ready 0% if thats what you mean. There is preload on the sensor when you install it. So even when your not pushing the gas it will read some sort of number as long as its not over 20% its fine. Not sure on the 75% reading, I cant remember if mine went to 100% or not at WOT. If I have time tomorrow I will hook up the scanner and double check.
Old Sep 13, 2012 | 02:07 AM
  #37
Trialmaster
From neons.org:
"The PCM does not use the percentage from the tps. The percentage is irrelevant. It uses the voltage dropped by the tps resistance"
Because my ideling is going slow down from 1200 rpm to 850 rpm, it have to be something wrong. Sometimes it stays at 1100 of 1000 rpm at idle.
Old Sep 13, 2012 | 08:54 AM
  #38
buddhaman's Avatar
buddhaman
Originally Posted by I_Ride_Neon
Quote:
Originally Posted by buddhaman
A tune will drop your times because I'd bet you're running lean.
There is a fine line where lean makes more power. A tune to allow his flow mods to actually work and make power, shouldn't make it run slower. On top of that he will get launch control, better rev limiter, better power bands, and so on. I wouldn't of invested all this money in calibrated, chipped, stand alone computers if it made my cars slower. Another benefit is the car will run much smoother and safer. I bet that a professional tune will indeed make the car faster.
When u said they'd drop his times I meant he'd get better times.
Posted from Dodgeforum.com App for Android
Old Sep 13, 2012 | 01:13 PM
  #39
Trialmaster
My ignition timing, when cruising at 60 mph, it reads about 35 dg advan. At wot from 60, it reads about 8-10 dg adv timing. When it Gora 40, it do not got any møre timing.
Old Sep 13, 2012 | 05:38 PM
  #40
ohioguru's Avatar
ohioguru
my sohc runs a 15.7 with a ebay intake and headder. 95 cam auto TB, polyurethane filled mounts, and falken ziex 512s
