Indy intake
Old Sep 11, 2012 | 06:39 PM
bostwickneonguy's Avatar
bostwickneonguy
Default Indy intake
is an Indy aluminum intake worth spending the 500 bucks on or could i make a decent ported OEM intake worthwhile...if so how hard is it to port One lol...just get a port kit and a gasket and go to town??? let me know
Posted from Dodgeforum.com App for Android
Old Sep 12, 2012 | 02:50 AM
Trialmaster's Avatar
Trialmaster
Are you going to install a turbo? Then its a good idea.
If not, you would go for a d90 stock intake, if you aint going over 8000 rpm with a ported magnum with big cam
You loose a lott of torque in the mid range with NA Indy combo.
But It looks cool
Old Sep 12, 2012 | 05:34 AM
bostwickneonguy
But It looks cool
eventually I will turbo but i guess ill just wait till I start building the turbo motor til then a d90 it is I guess lol how can I get my hands one tho??
Old Sep 12, 2012 | 06:44 AM
Trialmaster
You make one of the stock plasik intake. Cut it 90degres off, make a adapter to the tb.
But you can use it, as it is, and mount a 60mm Mpx tb you have to buy anyway.
Re locate battery is nesesery for d90.
Old Sep 12, 2012 | 07:11 AM
Trialmaster
Its a lot of work with turbo, but you got a m3 killer
I desided to go the Sohc NA way, and are soon hitting the 15.00 sec. Problems with wheel spin
Thats with crane 12 and some bolt ons and lth.
Old Sep 12, 2012 | 01:28 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Had a 2nd gen indy on my sohc (no 90 degree bend) on my 1st gen that ran low 14's on street tires. I also ran them on N/A dohc and turbo DOHC, along with a 60mm TB and the cars loved it. If you use the magnum manifold you will need an rpm switch to open the intake up (VTEC!!! lol). You may also need a 2nd gen starter because they are clocked a little different for more intake room.
Old Sep 13, 2012 | 06:48 AM
Trialmaster
The intake thread on .org, I can see, that the standard plastic picks up more midrange torque with a #14, than the Indy. But the Indy picks up wery well at 5000 and up.
Old Sep 13, 2012 | 07:13 AM
Trialmaster
That whas å fully ported Sohc on 10.5 pistons!
Sumary, on the hole powerband the d90 plastic and d90 Indy came out just even
Old Sep 13, 2012 | 07:22 AM
Trialmaster
I have å buddy with å Sohc, Indy 1. Gen, and Hahn stage1, running stock engine. He complains about lack of power under 3000 rpm. He has about 240 whp. Never seen a dyno...
Old Sep 13, 2012 | 05:17 PM
bostwickneonguy
I was wondering of you could explain a little better how to make a d90 intake and a tb adapter or direct me to a vid lol I'm gonna go with the cheaper one til I go DOHC
