1995 Neon Head Gasket
And the proper torque spec is 25 ft-lbs, 50 ft-lbs, 50 ft-lbs, then 1/4 turn, going inside to outside, correct? Following this: https://dodgeforum.com/forum/1st-gen...-question.html but wasn't sure if it changed from DOHC to SOHC...
Well, I think I had success -- will have to run it for a bit longer to see!
Anyways, I have a couple connectors that I can't seem to find where they go... One is near the throttle body, four-pin rectangle (there is another connector coming out of there that I already plugged in, around the same area) and a 3 pin circular connector near the camshaft position sensor (coming out around that same area, cam sensor is plugged in). Does anyone know where these go?
