rides like i have fat ppl in the trunk
Old Jan 4, 2013 | 06:05 PM
ohioguru's Avatar
ohioguru
Default rides like i have fat ppl in the trunk
lowered my neon on some megans with new gabriel strutts. and they have sucked from day 1. rides is great up front. but the rear is death. and 4 months later im pretty sure the rear strutts are dying. anyone know of another brand that can hold a 1.5 drop? for more than a few months? im not gonna spend 1k on konis or coils. its my dd and i just wanted a slight stance.
Old Jan 6, 2013 | 03:53 PM
Trialmaster's Avatar
Trialmaster
I have kyb gr2 with Eibach springs. Done 40000 km on them. Still firm. Remember its just 2.5" travel om a stock Neon, so you have to have the wright shocks.
Old Jan 6, 2013 | 04:27 PM
ohioguru's Avatar
ohioguru
the kyb gr2s are a oem replacment correct?
Old Jan 7, 2013 | 08:06 AM
Trialmaster
Yes, they are oem replacement.
Go coil over if serious about lowering a Neon.
Old Jan 9, 2013 | 11:59 PM
ohioguru's Avatar
ohioguru
if im gonna spend 1k on a neon ill pass. the cars rust free and paint looks new. but for my budget id rather sell my 1g and spend that grand on a downpayment for a srt.
Old Jan 10, 2013 | 12:15 AM
steak59's Avatar
steak59
Well, ur first mistake is using those Autozone Gabriel strut, LOL.
I think KYB is a strut supplier for Chrysler, so the GR2 is probably the OEM strut.
Eibach makes good spring as well, some Manufacturers put their name on it in their performance division. Like TRD on Toyota is atually Eibach spring.
If you are going to do everything over again, I highly suggest you to go with Trailmaster's combo.
Old Jan 10, 2013 | 02:33 PM
ohioguru's Avatar
ohioguru
ok and what coilovers are good choices that dont run 1k? its a dd. and yes the gabriels are junk. my 130k mile strutts took the drop longer than the gabriels did. for my spring i have a set of megans on it.
Old Jan 11, 2013 | 12:18 AM
steak59's Avatar
steak59
None, Coil over kit is always Go Big or Go Home type of deal. If you are going to use those budgeted "coil over spring" kit, you might as well just get struts with lowering spring.
Also, I think Koni makes adjustable rear struts for Neon, that might help your "fat ppl in back seat" problem.
Perhaps you should just change it back to KYB struts. They are fairly cheap.
Old Jan 11, 2013 | 04:03 PM
ohioguru's Avatar
ohioguru
ya the konis are like same cost as the coils. ok well seems that word is kyb's i can afford that.
Old Jan 12, 2013 | 07:52 AM
Trialmaster
4pc Kyb gr2 249$ at Modern. Thats not expensive
