Missfire Issues, Runs rough at Idle
Old Feb 3, 2013 | 08:55 PM
als99r/t's Avatar
als99r/t
Default Missfire Issues, Runs rough at Idle
Ok, I have a 99 R/T with mutiple missfire codes. #2,#3 cyclinder and random codes. I have Changed my spark plugs and wires. I have also tested the fuel injectors.Found that both #2 and #3 injectors were bad so I changed them.Did not fixed my rough idle or my trouble codes. You guys have any idea what else I should do?
Old Feb 6, 2013 | 06:39 PM
go-part's Avatar
go-part
Former Vendor
Misfires on specific cylinders are usually ignition or timing related.
Have you checked to see if you get spark through all the way to the spark plug?
You may just need a new ignition coil.
Old Feb 6, 2013 | 11:25 PM
als99r/t's Avatar
als99r/t
Looking Into it. I give an update soon
Old Feb 12, 2013 | 12:08 AM
als99r/t's Avatar
als99r/t
Replaced Coil and Cam sensor, It cleared all the codes I must have a pretty good exhaust leak because my car sound like a V8 with a nice cam
