Urgent!!! No fuel to engine!!! Need help!!!
PLEASE!!! Some one help me, I just replaced the fuel tank, fuel pump assembly, and battery. And there's no fuel to engine, I don't know what to do and if I can't figure it out my family said it goes to the junk yard): please help me ASAP, I put a lot of time and money into this car, I don't know what to do anymore, I checked the line running from the fuel rail and there's no gas at all, I figure it's an wiring problem but I dont know how or w hat to check, it's a 1996 neon SOHC 2.0 coupe
First off you need to check for power and ground at the pump when the key is turned to on. You will only get power for a second when the key is flipped. If there is power then the issue is the pump, or the wires inside the canister. If there is no power check power at the fuse and let me know what you find.
Zach's law: If it worked before you touched it, its more then likely something you touched.
