Miss fire saga continues
Well, this time around the car also had the P0743 Transmission solenoid code. I've replaced the solenoid a couple years ago, read on this forum to unplug re-lube with dielectric grease and see what happens. I did that after getting the car thru inspection by driving gingerly waiting for the drivability codes to clear and hit the nearest station. I then drove the car on the highway an hour up and down and upon deceleration on comes the CEL. Miss fires 0300, 0302,3,4. The following is the freeze frame data
Fuel System 1
Closed Loop
Calculated Load
20.7%
Coolant Temp
213
STRT Bank 1 (Don't know what this means)
-3.1%
LTFT Bank 1 (nor this)
.07%
Intake Manifold Press
4.2 in.hg
Engine RPM
2912
Speed
64
Any indication from this as to what the actual problem is? I'd like to have a direction before ripping parts off. Appreciate any comments or ideas.
Fuel System 1
Closed Loop
Calculated Load
20.7%
Coolant Temp
213
-3.1%
.07%
4.2 in.hg
Engine RPM
2912
Speed
64
