removing the turbo???
Old Apr 9, 2013 | 01:44 PM
wrongwaywillie13's Avatar
wrongwaywillie13
Default removing the turbo???
is it possible to remove the turbo and replace it with a higher compression pistons and have the car right good has a non tagged racecar
Old Apr 9, 2013 | 09:08 PM
darthroush's Avatar
darthroush
Section Moderator
You can replaced the turbo with a supercharger... Pistons are a whole 'nother thing.
Old Apr 10, 2013 | 07:52 AM
wrongwaywillie13
engine needs to be naturely aspirated
Old Apr 11, 2013 | 03:32 AM
darthroush's Avatar
darthroush
Section Moderator
Yeah, you can do all sorts of things to the engine and keep it N/A. You can raise the compression, add cams, adjust timing, change injectors and so on, like any other car. You just might need a new engine management system depending what you do.
Old Apr 11, 2013 | 07:55 AM
wrongwaywillie13
doesthe NA cars use the same crank has the turbo cars
Old Apr 15, 2013 | 12:34 AM
I_Ride_Neon's Avatar
I_Ride_Neon
I assume your talking about the 2.4 engine?? srt-4 or na? Whats it tuned on? I need more details. If your talking about the 2.4 dohc then the crank will interchange. Stroke is the same.
