99 dodge neon. turn key and nothing
Old 07-07-2013, 09:09 PM
blk99neon's Avatar
blk99neon
blk99neon is offline
Default 99 dodge neon. turn key and nothing
i have a 99 dodge neon and i turn the key one to start and i get nothing from anything. none of the gauges will work nor the light in the dash nor the radio. the a/c works and so does headlights. checked all fuses and relays and nothing is blown.... Please help asap!!!!!! thank you
Old 07-07-2013, 09:51 PM
FallenAngel92J's Avatar
FallenAngel92J
FallenAngel92J is offline
Battery good, all connections to battery and back are good, grounds, especially main ground off the battery, ecu wiring harness secure?
Old 07-07-2013, 10:25 PM
blk99neon's Avatar
blk99neon
all connections are good and secure. all fuses are good too. could it possibly be the ignition switch? i cut the car off for about a hour then went to leave and this happened and noting like this has ever happened before.
Old 07-08-2013, 12:16 AM
apollo-11's Avatar
apollo-11
apollo-11 is offline
Default 99 neon not starting
I have the same problem. Its probably the neutral safety switch wearing out. Just push the car back and forth. It should start.
Quick Reply: 99 dodge neon. turn key and nothing
