99 dodge neon over heating
Old Jul 29, 2013 | 12:07 PM
J'sMee's Avatar
J'sMee
Default 99 dodge neon over heating
99 dodge neon over heating, fans do work when hook directly to to battery, the a/c fan does not turn on when i start the car, have check the fuses and are ok. not sure what to check next?.
Last edited by J'sMee; Jul 29, 2013 at 07:42 PM. Reason: correct some words left out
Old Jul 30, 2013 | 10:42 PM
als99r/t's Avatar
als99r/t
relay and temp sensor
Old Sep 22, 2013 | 11:22 PM
monkeywrench305's Avatar
monkeywrench305
The cooling fan relay on neons is located underneath the battery on the drivers side frame rail, it is very exposed to the elements and is a common problem for these cars. It has a four wire connector and is bolted to the unibody inner fender. Also check to make sure the ground wire for the fans is connected, its right on top of the core support. there is a TSB regarding poor ground on that wire because of too much paint on the core support
