code 11 on 1999 neon pls help
Old Nov 17, 2005 | 06:39 PM
bouchez101's Avatar
bouchez101
Default code 11 on 1999 neon pls help
replaced head and cams on 1999 d.o.h.c on start up engine running rough, would not start without stepping on gas pedal now i have code 11
Old Nov 17, 2005 | 08:13 PM
casper's Avatar
casper
Default RE: code 11 on 1999 neon pls help
Check you timing belt, its probally one tooth off.
Old Dec 1, 2005 | 12:15 AM
Daddywags's Avatar
Daddywags
11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
