code 11
Old Sep 8, 2017 | 07:57 PM
mgebraankh9's Avatar
mgebraankh9
Default code 11
dodge neon 1996 got code 11 how to fix?
Old Sep 8, 2017 | 09:26 PM
Moving this to the neon section.
Old Oct 2, 2017 | 01:39 PM
92DakotaClub's Avatar
92DakotaClub
Intermittent loss of either camshaft or crankshaft position sensor,/No crank reference signal detected during engine cranking/Timing belt skipped 1 tooth or more from initial learned value
so either timing belt snapped, tensioner went , water pump failed...
other can be crank sensor or cam sensor as stated, or like it was in case of mine the wiring on back of engine between exhaust manifold and engine was melted to hell .. rewired and covered with nascar gas line heat shield.. no problems since..
