need wire help - installing starter/alarm
Old Dec 11, 2005 | 05:23 PM
ace_master's Avatar
ace_master
Default need wire help - installing starter/alarm
Im installing a remote starter/alarm (x-shield xs-800s) in my 1997 dodgge neon and am having trouble with locating some of the wires...
Here is a ling to the wiring diagram for the alarm i am installing
remote starter and alarm diagram
I need the location of the following
-Air conditioner(+)
-High Voltage ON
-Battery charging indicator wire/engine oil pressure indicator wire
And i know where the ignition wires are located, but dont know which wires are which colors for the following
-Starter
-On
-Accessory
-If you look on the bottom of the picture in the link above, you will see there is 4 wires going to the ignition, but only 3 labels, does anyone know what the 4th wire is?
Old Dec 13, 2005 | 08:30 PM
95SPRTcpe's Avatar
95SPRTcpe
Default RE: need wire help - installing starter/alarm
i'm not sure of the wire but incase you haven't already, i'd suggest getting a repair manual with the wiring diargam in it. it'd probley be some help because the list the color of the wire for what it is.
Old Dec 14, 2005 | 07:32 AM
RadarLove's Avatar
RadarLove
There are actually 4 wires coming from the ignition switch that you'll tap into. Been a while since I installed my setup though. I'd have to dig out the FSM (or just take a good look in there...) for that. PM me on this, so I'm not as likely to forget to look it up for you...
